Zoom in/out feature for BASES
Use the “control button” on the keyboard + “mouse wheel” to zoom in or zoom out in BASES view, like in any other Obsidian note.
Reason: currently the font size and table size is static in BASES, sometimes you need a bigger view of the fonts, the default font size in other notes is currently larger than the default BASES fonts.
Other use case, some people use BASES to show covers of books, games, movies etc. with control+mouse wheel you could zoom in/out to fit they view size to your needs in BASES.
This is a quality of life and ergonomic feature request, which could benefit all users and the consistency of the Obsidian behavour in all interfaces.
Alternatively/additionally you could add an option to Obsidian settings specifically for BASES, to adjust the default zoom settings.
Pressing:
“Control” button on keyboard + “mouse wheel”
like in any other Obsidian note to zoom in/out
Obsidian options => Display => “zoom the whole Obsidian GUI interface”
this is not the goal, because all other interface objects become larger/smaller, and you can’t quickly change the zoom size.
no similar feature request found so far.
Thanks in advance
I find this feature really important. Among other uses, I used Bases for Chinese and Japanese learning and a zoom in for kanjis and hanzis is critical, otherwise I can’t see much. Latin fonts look ok at that size. I stopped using Bases because of that.
