Zettelkasten Prefixer Not Working?
I’ve tried different variations of the folder path to create Z-notes, but all I get is an “untilted” note. Am I doing something wrong?
I’d like to keep the note at the root level since I’m using 1Writer for mobile and backlinks break in folders.
Does this help?
ss
If you’re using the hotkey cmd+N, make sure it’s for “create Zettelkasten note” instead of “create new note” in the Hotkey settings.
lol. I’m such a dope. Yes, thank you!
This also helps, thank you!
No worries. I did the same thing, haha :slight_smile:
