Yesterday's note: Open yesterday's daily note
Yesterday’s note
This plugin adds a command to Obsidian to open yesterday’s daily note. If the note does not exist, the plugin can create it for you.
Features
  • Adds a ribbon icon which opens yesterday’s daily note when clicked.
  • Adds a command “Yesterday’s note” which opens yesterday’s daily note.
  • Includes settings to:
    • Set a custom date format.
    • Set the file location where yesterday’s daily note is placed.
    • Use a template file for yesterday’s daily note.
    • Toggle whether a new note should be created if yesterday’s daily note does not exist.
FAQ
Why don’t you use the “Open previous daily note” command?
The Open previous daily note command is only available when a daily note is focused in the editor. This means to open yesterday’s daily note, you must enter two commands: Open today's daily noteOpen previous daily note. Also, the two commands aren’t exactly the same—one references the note for yesterday’s date and the other references the note that comes before the current note.
Why do I have to set the template file manually?
Obsidian doesn’t offer a way to directly retrieve the template file used for creating daily notes. Due to this limitation, my plugin can’t automatically detect the template file, so you need to set it manually.
Yesterday’s note isn’t using the correct template file
The Template file location is case sensitive. If the file you want to use is templates/Daily.md, templates/daily.md will throw an error. Please ensure the path and file name are correct.
Issues
Open an issue in the repository on GitHub or get in touch.
NOTE: The plugin has been submitted for review. Until it is approved, you can install it manually by following these instructions:
  1. Download the main.ts and manifest.json from the latest release on GitHub.
  2. In your vault, create a new directory called yesterdays-note in the .obsidian/plugins directory.
  3. Move the files from step 1 to the new yesterdays-note directory.
  4. Restart Obsidian.
  5. Enable the plugin from the Community plugins settings page.
Funnily enough I submitted this plugin just a few hours after this plugin with similar functionality.
Here’s the GitHub repo for it.
I tried it out but prefer my plugin for the following reasons:
  • Ability to use a custom date format. Defaults to the Daily notes date format.
  • Ability to set the file location where the note will be created. Defaults to the Daily notes file location.
  • Ability to use template files.
  • Ability to create yesterday’s note if it doesn’t exist.
