- Create a document with multiple lines
- Try to copy the first three lines using
:1,3y
- Try to paste using
p
The first three lines gets pasted after the cursor
The line the cursor had been at when :1,3y
was used, was yanked and pasted instead
For example, line 4 will be pasted if the cursor was at line 4 when the command was typed
Obsidian version: v1.4.16
Installer version: v1.4.16
Operating system: #202310061235~1697396945~22.04~9283e32 SMP PREEMPT_DYNAMIC Sun O 6.5.6-76060506-generic
Legacy editor: off
