Workaround for problem with non-standard Android?
Hi there,
is there any workaround for the problem with some Android-Systems, where you can not open or create a vault?
Mentioned e.g. here:
https://forum.obsidian.md/t/android-unable-to-open-folder-or-create-new-vault/86209
https://forum.obsidian.md/t/bug-android-app-wont-create-open-vaults/36232
https://forum.obsidian.md/t/android-cant-create-or-open-vault/55876
I would love to get Obsidian running on my InkBook Focus Color, wich is running inkBOOK OS compatible with Android 11.
The solution to (re)install the native File Explorer App doesn’t work out, cause it keeps crashing.
Would be thankfull for any hint!
