insert a callout CNT+P /insert callout
Add some text with some words Capitalized, like Paris
the text will be rendered as “pairis”
About Obsidian
Version 1.6.3 (Installer 1.4.14)
I can’t reproduce.
Please, Post a screen recording of this happening in the sandbox vault
It looks like you are putting an emoji and text in the callout name:
> [!✏️ Move to Paris in December 2025]
> Contents
That’s not how callouts work.
You want:
> [!todo] ✏️ Move to Paris in December 2025 <-callout title
> callout content
> [!info, todo]
> [!note]
> [!abstract, summary, tldr]
> [!tip, hint, important]
> [!success, check, done]
> [!question, help, faq]
> [!warning, caution, attention]
> [!failure, fail, missing]
> [!danger, error]
> [!bug]
> [!example]
> [!quote, cite]
you are not using the correct syntax
thanks! this had me quite baffled. You are correct.
