- Create a new Vault
- Open the menu in the right corner and select “Stack Tabs”
- Create a new file, enter “—”, add a date property and select a value
- Add some demo content so that the content can be scrolled
- Scroll down a bit so that the date property is approximately in the middle of the title bar (that doesn’t show tabs anymore because of the stacked tabs).
- Try to drag the window by dragging in the middle of the titlebar (where the date property is behind)
The window can be dragged (everywhere in the title bar)
- Doesn’t work, the window cannot be dragged at this position
- Repeat the same with a text property instead of a date property => Works fine, no problems
Obsidian version: v1.5.12
Installer version: v1.5.3
Operating system: Darwin Kernel Version 23.2.0: Wed Nov 15 21:53:18 PST 2023; root:xnu-10002.61.3~2/RELEASE_ARM64_T6000 23.2.0
Catalyst license: insider
Insider build toggle: on
VIdeo: drag.mov
