Wikilinks or Markdown links for Zettlr compatibility? full path?
I’m not asking for a full explanation on how links work, just point out the recommended format and I’ll figure out the rest :slight_smile:
  • Set up my new links in Obsidian so there’s less friction when using my notes in combination with Zettlr
  • If possible, a way to convert my existing links to the most compatible format
I read that using wikilinks might be better than markdown links, but no idea about shortest or absolut path.
  • I tried years ago without succes, I don’t remember much
  • Now I’ve searched the forum and the net but I didn’t find enough info, so before I spend, again, too much time on this, I thought somebody here could drop me a line and save me a lot of trouble.
Thank you.
I’d check Zettlr’s documentation to see what style it uses. They probably don’t use the same terms but hopefully describe how they behave / what the output is, and then you can match it to what Obsidian offers.
I figured that someone here could post the answer without effort, but if that’s not the case, you’re entirely right: their documentation will help me figure it out :slightly_smiling_face: Thank you.
