In help system the only name you can find is Internal link . If you search help for Wikilink you will get zero results.
From the other hand, corresponding Obsidian option calls them Wikilinks
And community calls them Wikilinks most of the time.
I suggest Wikilinks alias to be added as a synonym to the help documentation.
FYI, changes / corrections / additions to the help documentation are handled through GitHub:
Obsidian Docs → Missing or outdated content.
Angel
koala
3
See this comment, the option just allows to specify the type of internal link to be used, which can bei either wikilink or markdown link.
system
Closed
4
