I have a note named “issue”
with given “alias” property “alias_name”
aliases:
- alias_name
Some lines
^label
If I link to that note
[[issue|alias_name]]
I see correct link text "alias_name"
With
![[issue|alias_name]]
I get get the body of the note with original note name
> **issue**
> Some lines
But not the "expected" alias as "header" text
> **alias_name**
> Some lines
I have a workaround - but then no "header"
![[issue|#^label]]
and no idea to show the alias name....
Did you follow the troubleshooting guide? [Yes]
Its all basic obsidian, only activated property plugin
Declared above
Declared above
None
Some information for you about the usage of “issue”
All notes of shown type “Issue” contain a short text and are named (note name) with a specific prefix (like notes in Zettelkasten).
At that moment I do not find an option to work around not to get these (name) prefixes because I miss the possibilty to show referenced “name of note”, “note body” or the value of “aliases” property (I know, its a list
)… All overkill. It could be so easy.
