Write Mathe equations along with taxt in LaTex
Asking google
$$ {x|E(x)}\to Menge \ aller \ x \ für \ die \ gilt \ :E(x)$$ would be an example which is displayed as: {x|E(x)} → Menge aller x für die gilt :E(x) in the edit mode but in reading mode, the text part crashes to gibberish
It works in my reading mode.
Show your device info (Windows, Mac, Android etc.)
Did you try to disable all plugins?
Troubleshooting Guide
Search before posting
Before opening a new bug report, please try searching the whole forum for duplicates. It really helps us.
Troubleshoot Instructions
In order for us to fix a bug, we need reliable and consistent steps that cause the bug every time.
If something looks wrong, first make sure you are using the latest Obsidian version and that your installer is up-to-date. The app and installer versions don’t need to match, but they shouldn’t be too far apart.
The instal…
Workaround
Use \text{}
or \textrm{}
A tip for future forum posts: when you paste or write text examples, mark them as code to be sure we see exactly what you’re seeing.
