Why does Images and other stuff don't get exported to PDF?
Why when I try to export a Note into a PDF some or most of the images don’t get exported? only their link does, it is also the same with some of the effects with text such as Bold, and other stuff.
How can I solve this problem?
I have tried to change the links of the images but nothing worked.
I cannot reproduce this on Obsidian 1.5.12 on Fedora Linux 40. Both graphics and text formatting are properly formatted using the standard “Export to PDF…” command.
Sadly, most of the pictures I had put while I was writing in Obsidian 1.5.12 seem to disappear when I export them to PDF, and only their link-like: ![[894998.png]] remains.
what can I do??
Is the better export pdf plugin a workaround for you?
