When the app was last closed in fullscreen, on startup / load in, its windows is bright white until it starts loading. I used the new installer so it’s probably to do with the new Electron version.
flash
I’m on Windows 10, v0.13.30.
there is another electron update in 0.13.31. Not sure if it’s gonna solve your problem. I can’t repro it.
I have the same issue on Windows 11. Occurs when using 0.13.31 as well
thanks I can repro this now.
will be fixed in 0.14 0.13.32
