Hi, Obsidian Teamers,
since I have three older Macs and only one is capable to run Obisian, could you please tell me which OS is required do run it?
Regards
Thies Stahl
Regards
Thies Stahl
All the older Obsidian versions are here:
You didn’t say what macOS version(s) your older machines are running, so we can’t really direct you to the last installer of Obsidian that can be installed on them. Once the older installer is, uh, installed, you can update within Obsidian if it’s not too old.
