I want to create a new vault B, that is also synced to remote vault B.
B should have the same settings, themes, plugins, … as an existing vault A.
A is synced to a remote vault A.
Solution Idea
Copy all the settings, themes, … from the .obsidian folder of vault A to local folder vault B, but leave out the settings for the remote vault.
Because I don’t want to sync local vault B to remote vault A.
Problem
I can’t find the remote vault setting in the local vault.
Question
Where is it stored?
Any better solution to quickly and save duplicate/migrate settings, themes, plugins, … to other vaults, while skipping the remote vault setting?
Additional question, even if it is slightly off topic:
I realised that the file ./obsidian/workspace.json is referencing the .md files from the vault A. These .md files are NOT in vault B.
Can I safely copy the workspace.json file to vault B? Is it purged from missing .md files?
Shall I skip copying the workspace.json file?
