Type a math function and start the line with $ to indicate as such. For example:
$a = b * c$
$a = b * c$*
There will be an extra asterisk that shows up.
I can’t repro this. Can you post a short gif\video?
Ok, I think I get what you mean. Why would you wanna use * in a formula? I don’t recall ever using it. I think it’s pretty rare.
You can disable auto-completion for * if you want and it seems to happen only if there is whitespace before the star.
It’s the symbol for convolution:
I would simply use \ast instead: $f \ast g$
This is a conflict with the Autopair markdown syntax preference I believe, turning it off you can still format things with bold/italics by selecting them and using a hotkey.
Upon further thinking, i don’t think this is a bug. Because, we have no way of knowing if you put a $ for dollar or a $ for starting a formula.
If you use a lot of convolutions, I would disable the auto-pair of *.
Thanks for the replies. I’m new to LaTeX and see that I should be using \times for multiplication. This can probably be closed. Yes, I do have auto-completion enabled.
\times
