When I scroll in a long note, I’ve noticed that sometimes the rest of the note, beyond the initially visible text, doesn’t load in, till you click.
  1. have long note
  2. scroll
  3. rest of note doesn’t load
  4. click
  5. visible text loads
  6. scroll more
  7. have to click again
automatically loading of text when scrolling?
having to click when you scroll, otherwise text stays invisible that wasn’t initially on screen.
  • Operating system: Linux Mint
  • Debug info:
    Obsidian version: v0.13.23
    Installer version: v0.12.15
    Operating system: #29~20.04.1-Ubuntu SMP Fri Jan 14 00:32:30 UTC 2022 5.13.0-27-generic
    Legacy editor: off
    Base theme: light
    Community theme: Shimmering Focus
    Snippets enabled: 24
    Safe mode: off
    Plugins installed: 39
    Plugins enabled: 34
    1: Timeline
    2: Templater
    3: Tag Wrangler
    4: Tabout
    5: Style Settings
    6: Smart Typography
    7: Sliding Panes (Andy’s Mode)
    8: Settings Search
    9: Activity History
    10: Admonition
    11: Advanced Tables
    12: BUmBLe
    13: Custom window title
    14: Customizable Sidebar
    15: Cycle through Panes
    16: Dataview
    17: Excalidraw
    18: Find unlinked files and unresolved links
    19: Force note view mode
    20: Gallery
    21: Hide Sidebars When Narrow
    22: Kanban
    23: Link Headers Directly
    24: Maximise Active Pane
    25: Natural Language Dates
    26: Number Headings
    27: Obsidian Git
    28: Obsidian Tabs
    29: Outliner
    30: Ozan’s Image in Editor Plugin
    31: Page Count
    32: Pane Relief
    33: Remember cursor position
    34: Macros
Custom theme: for cosmetic issues, please first try updating your theme to latest. If still not fixed, please try to make the issue happen in the help vault or disable community theme and snippets.
Community plugins: for bugs, please first try updating all your plugins to latest. If still not fixed, please try to make the issue happen in the help vault or disable community plugins.
This does NOT happen in a blank vault or in the help vault, even if I paste a lot of text and scroll. However it DOES happen in my main vault even if turn off ALL plugins and snippets, and use the default theme.
So I’m thinking it has to do with the size of the overall vault? I have 380 notes and 1 GB.
See this video for what I mean: Obsidian Scroll - YouTube
Disable plugins, themes, and css snippets. Restart Obsidian.
Post a screen recording of this happening.
Ok, so I disabled everything, restarted and it wasn’t happening anymore. Now I re-enabled everything, restarted, and now it’s also not happening anymore. So, I’m not sure what was happening, but as you can see it the linked video, it was indeed happening.
If it’s ok, I’d like to leave this open for now, because since I’m not sure what’s different now, it might reappear. Or if anyone has any ideas what might have been happening, that’d be cool :slight_smile: Thanks!
If you are able to reproduce this bug in the help vault or in your vault but with everything disabled (and restart), open a new bug report, attach a screen recording and a file where this is happening.
Ok, thank you :slight_smile:
