When editing formulas in Base in a separate window, input becomes disordered
  1. Drag Base into a separate window
  2. Edit a formula
  3. When entering any non-a-z characters (including .), the editing cursor jumps around
Y
Text input should function normally within formulas
In reality, whenever any other characters are encountered, the cursor jumps erratically.
	Obsidian version: v1.9.10
	Installer version: v1.9.10
	Operating system: Windows 11 Pro 10.0.22631
	Catalyst license: none
	Insider build toggle: on
	Snippets enabled: 1
832394a4-136b-440b-89f4-a0101ea841f5
that’s interesting
  1. Open a (.base) file in a new window
  2. Go to advanced filter or add a formula-property
  3. Create code for the filter or formula
  4. Manipulate the created code
Y
  1. When double-clicking to select text or positioning the cursor within the code, both function correctly.
  2. When deleting a character from the code, it does not cause a jump.
  1. Double-clicking does not select the text, and clicking on a part of the code does not position the cursor.
  2. When deleting a character, the cursor jumps.
Recording
Obsidian version: v1.9.12
Installer version: v1.9.12
Language: es
Base theme: light
using sandbox
Should be fixed in 1.10.5
