When dragging and dropping from Explorer, have link order based on selection order
When selecting a range of files in the Explorer by clicking the first file, then shift clicking the last file, click dragging the resulting selection into a note does successfully add the links to all the selected files. However, no matter what I try, I have been unable to get the order of links to be correct. It will always have the last file in the range as the first in the order. But, after that, it will successfully have the first file selected in sequence all the way to the file before the last file selected in the range.
It would be nice if the links were added to the note in the order that they were selected. This could be extended to a unique custom order by jumping around selecting files using alt click.
Thanks!
