What syntax should be used to index Kanban tasks with Dataview?
If someone would want to currently make use of Dataview for daily notes.
What syntax should be used to index Kanban tasks?
This didn’t fit the discussion it was originally posted in, so I moved it to its own topic. You may want to add more here so that folks can better help you!
Hey thanks. I was trying to understand the current integration level. Maybe i should had written it more clearly, as it wasn’t intended as a support post. My bad.
