What is the reason for while exporting why note layout are changing
I just wrote everthing what i want, but after export as PDF the note layout is changed.
I wrote one line and after i added a point after that i wrote a sentense that’s not points in the UI is ok, after export as pdf the second line after which after the point, the sentence is aligned to the point.
This is i wrote.
This is after export.
I eported multiple time but its happaning again.
Click this book icon here:
That will switch you to “Reading view” which will be the closest to and probably matches the PDF export.
