What is the CSS Class associated with header fonts?
Picking through various themes codes, changing editor font, changing preview font, using various plugins that allow changes to the font through themes, I cannot seem to find the correct class to change JUST the header fonts (in both editor and preview). I have also checked through the CSS as best I could in developer mode to no avail… I’ve tried --h1-font-family, --h1-font --h1-fontfamily, --h1-text-editor etc etc… I have also tried a CSS Snippet using the following
h1 {
  font-family: arial;
and have made sure to enable the snippet.
Edit: I have had some success in that the code snippet DOES apply to the preview, but not to the editor, which is the other CSS class I cannot seem to figure out.
h1 {
     editor-text: arial;
Where editor-text is I have also tried editor-font-family etc etc…
Set a unique font for my headers that is different from the rest of the editor/preview fonts, ideally through CSS snippets or something similar. I’m not sure the order in which things apply (Themes < CSS Snippets would be what I would expect but again, not sure.)
Thank you!
I continued to do some digging and found this topic about customizing header colors and that proved to be the key.
.view-header-title {
 font-family: arial;
.cm-header-1
font-family: arial !important;
.cm-header-2
.cm-header-3
.cm-header-4
.cm-header-5
.cm-header-6
.markdown-preview-view h1
.markdown-preview-view h2
.markdown-preview-view h3
.markdown-preview-view h4
.markdown-preview-view h5
.markdown-preview-view h6
Solved :slight_smile:
i guess to help u reduce the clutter (since u want to use same font family for all headers) of the above css snippet, you can write it as per below
.view-header-title { font-family: arial; }
/* change header font in editing view */
.cm-header-1,
.cm-header-2,
.cm-header-3,
.cm-header-4,
.cm-header-5,
.cm-header-6 {
/* change header font in reading view */
.markdown-preview-view h1,
.markdown-preview-view h2,
.markdown-preview-view h3,
.markdown-preview-view h4,
.markdown-preview-view h5,
.markdown-preview-view h6 {
Thank you! Much appreciated :slight_smile:
