What is the best way to Publish Dataview tables?
Hi people,
What is the best way you have found to Publish Dataview Tables?
That is for somebody that is not a programmer?
I thought about doing it the way Josh Plunkett explains it in his video:
but that seems like it is easy to mess up somewhere as a non-coder.
Then you have the plugin Enveloppe and I have set it up and got the error that there was no branch main found.
What are you people using and what can you recommend?
To get the result from a Dataview query to be shown when publish, requires it to be persisted. I currently know of two plugins do this: Dataview Serializer and Dataview Publisher. I’ve not used either, since I don’t publish stuff related to my vaults, but I do believe the Dataview Publisher looks the best and most promising.
