What is a good structure for assets or a clean structure for a workspace vault in general?
Hello
this may go into the developing category as well as soft-question but I think it had found a better placement here.
The ObsidianStarterVault by SoRobby has a Vault directory inside and for the assets a data folder with:
  • media
    • banners
    • other image files
  • pinned
  • scripts
    • dataview and javascripts
and
  • templates
    • for all kinds of things
Especially to the _data_ ( assets ) folder I would like to ask how to correctly enter the folder in the textfield in
Options -> Files and Links -> Default location for new attachments -> Attachment folder path
Is it sufficient to enter /_data_/ here to include all subdirectories as well or is it a comma-separated list that I have to curate myself?
And what about this Vault folder inside the vault folder ? Can someone explain the sense of this to me?
Thanks
coreSpotz
The structure looks like this when you unzip the file:
└── ObsidianStarterVault-main/
        ├── README.md
        └── Vault
You want to use Obsidian’s Open folder as vault option to open the Vault folder. That’s the root of this sample vault. It should look like this in Obsidian:
Screenshot 2024-01-29 151536
It looks like they’ve already set Default location for new attachments to _data_/media, so all new attachments, no matter, the type (.jpg, .pdf, .mov , etc.) will go in there.
Screenshot 2024-01-29 150519
Thanks to you!
coreSpotz
