What code for emoji from Lucid?
e
I asked about code for Lucid emoji
I see that code is
I see that code is formated variously for the emjo called Lucid. What is Lucide? – Lucide
What should I use for Obsidian?
I looked in the documents and found Lucide, Credits - Obsidian Help
But that did not tell me which type of code to use. I tried copying code, but I do not know where to put is. Tried other copying but nothing worked.
What’s the context here, are you trying to build a plugin or create a custom callout?
I would not be able to build a plugin. But, I was trying to change the package icon in the Properties plug in. There is something that I should copy on the Lucide URL page. I was not able to bring it up.
Thanks
I found the correct the code that I was looking for. I think I was on the wrong URL.
