Before opening a new bug report, please search the forum for duplicates and follow the Troubleshooting Guide.
- We only consider bugs that are reproducible in the sandbox vault or a vault with no third-party plugins/no css snippets/default theme.
- For Linux, we only accept bug reports that are reproducible with our Appimage package under Gnome or KDE.
- Developer issues with the API should go here
- Themes and Custom CSS issues should go here
I am using the official Obsidian Web Clipper plugin on Chrome and tested it on L-space of a statistical experiment.
To reproduce, one just web-clips the page.
Yes
The LaTeX expressions are off. For example the first block (between b) and c)) should be
L^{′} \left( \mathcal{E} \right) = \left\{ \mu \in ca \left( \Omega , \mathcal{F} \right) : \left| \mu \right| \leq \sum_{i = 1}^{n} \left(\alpha\right)_{i} P_{i} \right.
And if correctly rendered:
The extension saves following LaTeX snippet for the block
L^{′} \left(\right. \mathcal{E} \left.\right) = \left{\right. \mu \in ca \left(\right. \Omega , \mathcal{F} \left.\right) : \left|\right. \mu \left|\right. \leq \sum_{i = 1}^{n} \left(\alpha\right)_{i} P_{i}
failing the rendering:
The main problem is that \left{ should have been \left\{. There are also minor issues
- Excessive
$(one more) - Excessive
\left.and\right.
Obsidian:
Obsidian version: v1.7.4
Installer version: v1.7.4
Operating system: Windows 11 Education 10.0.22635
Catalyst license: none
Plugins installed: 1
Plugins enabled: 0
obsidian-web-clipper-settings.json:
"general_settings": {
"betaFeatures": false,
"legacyMode": false,
"showMoreActionsButton": false,
"silentOpen": false
"highlighter_settings": {
"alwaysShowHighlights": true,
"highlightBehavior": "replace-content",
"highlighterEnabled": true
"interpreter_settings": {
"anthropicApiKey": "",
"defaultPromptContext": "{{fullHtml|strip_tags:(\"script,h1,h2,h3,h4,h5,h6,meta,a,ol,ul,li,p,em,strong,i,b,img,video,audio,math,tablecite,strong,td,th,tr,caption,u\")|strip_attr:(\"alt,src,href,id,content,property,name,datetime,title\")}}",
"interpreterAutoRun": false,
"interpreterEnabled": false,
"interpreterModel": "gpt-4o-mini",
"models": [
"baseUrl": "https://api.openai.com/v1/chat/completions",
"enabled": true,
"id": "gpt-4o-mini",
"name": "GPT-4o Mini",
"provider": "OpenAI"
"enabled": true,
"id": "gpt-4o",
"name": "GPT-4o",
"enabled": true,
"id": "gpt-o1-mini",
"name": "GPT-o1 Mini",
"baseUrl": "https://api.anthropic.com/v1/messages",
"enabled": true,
"id": "claude-3-5-sonnet-20240620",
"name": "Claude 3.5 Sonnet",
"provider": "Anthropic"
"enabled": true,
"id": "claude-3-haiku-20240307",
"name": "Claude 3 Haiku",
"enabled": true,
"id": "claude-3-opus-20240229",
"name": "Claude 3 Opus",
"openaiApiKey": ""
"property_types": [
"defaultValue": "{{title}}",
"name": "title",
"type": "text"
"defaultValue": "{{url}}",
"name": "source",
"type": "text"
"defaultValue": "{{author|split:\", \"|wikilink|join}}",
"name": "author",
"type": "multitext"
"defaultValue": "{{published}}",
"name": "published",
"type": "date"
"defaultValue": "{{date}}",
"name": "created",
"type": "date"
"defaultValue": "{{description}}",
"name": "description",
"type": "text"
"defaultValue": "clippings",
"name": "tags",
"type": "multitext"
"template_1730565378021qs4gz44zh": [
"ᯡࡅ䁬⁼ၦǸڀƠ嘡壴䈡慠♘ɘڐˠ᳠៙珈Ƃ:ࠡ氤ᠫ〴挨BḠ昼ż|Ⱡĸ硐瀦猠ྀԏ怸懇䎴彶㚋ء旘砣ઊ灟永ᒩḡ㼏㈠ᰭ̨ⓡ廾ざ╉ᙤ梀୳㈸ኌ᪖⏖幑ᕉ疴摄砠ẉဿں寧䇌爂䝠Ǖ₰繤⩆ᬯࡧ͵ᇡ撰㰠歘᭔㋿䴊牑͈㡄抜瓇坝泤檥䋗僐㤘⊊㋕Į⡣⦮稙⒊ㄭ㛔皞㣒Ґ㱩噗恻碄⻣偙怠㮧ూ䡘䋗䡲榬燌โ䠸䵌䌐ⰼ怲ከ栠ὲᯬ३倠ݥ䀠ࣩ屨ᘤೠ悻ࡕ戠⭕ᱍ窌ⴠ㷏妕䩪Ȣ㮰岍ᯭ㧝幑રాਪ揂潧ችᖡ㌙⎻禒浝叄〈ដටᇡᐹḳ㫡㪝რ哬猬⦁8ṏᶉ枍峝㠾n⇖䩡⊶寢瑁㎾፦ᷪ瀢ᵁ⏾䋷滈ଊ䤞用ム㐨᰼⢸㢱Ვ燳ˁ㡲徐Ú嘴䇃ň䨵❷唻眰 "
"template_list": [
"1730565378021qs4gz44zh"
"vaults": []
