Web Clipper selection capture fails on Chrome/Edge, imports entire page
Hello everyone,
I’m experiencing an issue with the official Obsidian Web Clipper extension. The feature to capture only the selected or highlighted text is not working. Every time I try to use it, the clipper imports the entire webpage, ignoring my selection.
When I select a paragraph on a webpage and use the “Clip selection” feature, I expect the new note in Obsidian to contain only that selected paragraph.
What’s actually happening
A new note is created, but it contains the full content of the entire webpage. The selection is ignored.
My Environment
  • Obsidian version: v1.5.12
  • Operating System: Windows 10 Pro
  • Browser(s):
    • Chrome: v125.0.6441.208
    • Edge: v125.0.2535.94
  • Web Clipper extension version: v0.12.0
Things I have already tried
  • I have fully updated both browsers to the latest version and restarted the system.
  • I have tested in Incognito/Private mode with all other extensions disabled.
  • The issue occurs on various simple websites (like Wikipedia), so it doesn’t seem to be site-specific.
  • I know this feature used to work in the past, as shown in several video tutorials.
It seems to be a compatibility bug with the latest browser versions. Is anyone else experiencing this?
Thank you!
In Obsidian’s Web Clipper settings, what’s the option you chose for the Clip behavior under the Highlighter section ? :blush:
From my quick test on wikipedia (in a completely different environment though :sweat_smile: ) the option Highlight the page content captures the whole page and adds markdown highlights around the clipped content in the page (e.g.: ==clipped content==).
The Replace page content on the other hand, only clips/captures the highlighted content on the page …
Maybe you just need to change that setting ? :woman_shrugging: :blush:
