Web clipper recommendation?
EDIT: The official Obsidian Web Clipper is now available and can be downloaded for all major browsers:
Hi
I am looking for a web clipper that is privacy respecting and works locally? I used to use Joplin Web clipper, I liked it a lot so I am looking for something like that. I will be using it on Win and Linux
Omnivore can be self hosted but it offers device sync, see Omnivore.
Open source, local, and integrated with Obsidian.
(I use Omnivore as suggested by @blue_emperor )
This does not look integrated into Obsidian directly. I am looking for a clipper that can clipper to Obsidian directly.
@exztz1 are you replying to me? It’s literally on the link I sent you…
https://github.com/deathau/markdownload#obsidian-integration
Omnivore is also directly integrated, plugin and everything.
DominikPieper/obsidian-ReadItLater
Website URL
Will be parsed to readable form using Mozilla Readability and then converted to markdown. In case website content is marked by Readbility as not readable, empty note with URL will be created.
If enabled, images will be downloaded to folder (default is ReadItLater Inbox/assets) configured in plugin settings. (Supported only on desktop for now)
