Given the Breaking Changes in 1.9.10 to the tag/tags property; is this a bug?
My clipper template has the tags property set as multitext, so when the clip is copied into my vault, the tags are not set correct. See this example:
Note: the property is the correct type in the vault. But I guess the imported “text string” tags are not converted correctly into “property” tags.
