I’m encountering an issue with the Obsidian Web Clipper and would appreciate your help. When I clip web pages, the images from the page are being moved to the very end of the note. This makes it quite difficult to read and understand the content.
I would normally expect the images to remain in their original positions within the web page content. However, after clipping, all the images are listed at the bottom of the note, separate from the text content.
I am currently using the default note template. I haven’t applied any custom templates or CSS.
Does anyone have any ideas about the possible causes or solutions for this issue? How can I fix this?
Thank you in advance for your help.
Hopefully you do, but if you don’t get any replies here, I’d check out the Obsidian Discord server’s #obsidian-clipper channel. It’s very active and lots of folks with clipper experience hang out there.
if you could would be really helpfull becaus our government has blocked to access to discord and we can’t reach for a while.
Hello.
If content is missing or being wrongly structured, have you tried:
Some content is missing
By default, Web Clipper tries to intelligently capture content from the page. However it may not be successful in doing so across all websites.
Web Clipper uses Defuddle to capture only the main content of the page. This excludes header, footer, and other elements, but sometimes it can be overly conservative and remove content that you want to keep. You can report bugs to Defuddle.
To bypass Defuddle in Web Clipper use the following methods:
- Select text, or use
Cmd/Ctrl+Ato select all text.- Highlight content to choose exactly what you want to capture.
- Use a custom template for the site.
If you can access GitHub, you can report issues there:
I had tried all of your suggestions, I just tried them again, but the same problem persists with all of them. In both the highlight method and manual selection, the photos always get pushed to the end, and the problem continues. I am reporting this as a bug. thank you ![]()
I also tried the custom template, and in that one the photos also go to the end.
Hi.
Clipper bugs need to be reported on Discord or GitHub:
If you encounter issues with Web Clipper you can get help via the official Discord channel. You can also report bugs on the GitHub repo.
Out of curiosity, possible to share a link to a page where it doesn’t work? Someone might be able to help on the forum.
Yes, @Cagataytuylu, please share a link where you see the issue when clipping. Hopefully someone can have a look.
