I’ve updated to the newest Web Clipper version (0.10.1), and re-inserted my keys.
I was hoping that the next version of Web Clipper will allow us to set the default interpreter used within each template. That way, we could turn on the “Automatically Run” behavior, since the template had loaded the interpreter of choice.
For example, I have 2 Web clippings templates, each that works best with a different interpreter.
Add a new “default interpreter” option in a single Template’s setting.
This new setting would looks similar to the Vault chooser, it could have a “Last Used”, and then it could list all the available interpreters added from the Interpreter options page.
- Turning off “Automatically run” for the Interpreter behavior.
- Choosing the interpreter for each template that has an interpreter.
- Interpret
