Following the previous conversation Wash-out or "dull" colors on HDR10 Monitor.
In order to show the following example, I am using this plugin: GitHub - deathau/cm-editor-syntax-highlight-obsidian: A plugin for [Obsidian](https://obsidian.md) which allows syntax highlighting for code blocks in the editor.
to color some of the text.
Notice the difference on the text tags orange.
This is how the colors look on a wide gamut monitor: RGB (218, 157, 64)
And this is in a normal gamut monitor: RGB (228, 159, 51)
Images also are off to some degree.
Here is the original image:
The original color is: RGB (255, 0, 0)
Pasted on a normal gamut monitor, I get: RGB (232, 54, 19)
Pasted on a wide gamut monitor, I get: RGB (213, 40, 16)
Capture from the wide gamut monitor: RGB (213, 40, 16)
The colors should be the same. For text and images.
- Operating system:
Windows 11 Pro
22H2
22621.1413
Windows Feature Experience Pack 1000.22639.1000.0
- Debug info:
Obsidian version: v1.1.16
Installer version: v1.1.15
Operating system: Windows 10 Pro 10.0.22621
Catalyst license: none
Legacy editor: off
Plugins installed: 1
Plugins enabled: 1
1: Editor Syntax Highlight v0.1.3
Conclusion
Also tried without the plugin “Editor Syntax Highlight v0.1.3”.
The issue is fixed if I set:
C:\Users\xxx\AppData\Local\Obsidian\Obsidian.exe --force-color-profile=srgb
Is there any way to permanently fix this? Thanks!
