- Enable Vim key bindings
- Open a note containing a multi-codepoint emoji such as https://emojipedia.org/right-arrow#technical
- Place the cursor before the emoji
- In vim normal mode move the cursor until it is past the emoji
Y
The cursor moves over the emoji just like non-emoji text.
After initially highlighting the emoji character, the cursor disappears on its next move (or next several depending on the number of codepoints) and eventually reappears once it is moved to the subsequent character.
Obsidian version: v1.4.13
Installer version: v1.4.13
Operating system: Darwin Kernel Version 22.6.0: Fri Sep 15 13:39:52 PDT 2023; root:xnu-8796.141.3.700.8~1/RELEASE_X86_64 22.6.0
Catalyst license: none
Legacy editor: off
