(this Video is propably of value: https://youtu.be/Y-2uWDOhDgY
- Activate Vim Mode.
- Create a table with table cells having 3+ lines (using
Shift
+Enter
) inside them (which is realized by using<\br>
in markdown). - Navigate inside the table cell using j & k and h & l.
j/k should move down/up to the upper/lower line inside the table cell.
h/l should move to the left/right in the current line inside the table cell.
j/k skips the most lower/upper line (goes to the previous/next row too early).
h/l goes to other cells inside of moving inside the current line (if the current line isn’t the most upper line).
Obsidian version: v1.9.10
Installer version: v1.9.10
Operating system: Windows 11 Pro 10.0.22631
Catalyst license: insider
Insider build toggle: on
Plugins installed: 0
Plugins enabled: 0
- Video:
(same as above).
