Starting with v0.15.1 I noticed that Control-D in Vim mode deletes the character under the cursor instead of paging down. Anyone else experiencing this?
Bug appears to be upstream in CodeMirror. Filed an issue here:
The problem can be duplicated in the online demo:
https://codemirror-vim--util.repl.co/
thanks
will be fixed 0.15.3
It’s not a proper fix, and it doesn’t help with Ctrl+Y
that broke just as well, but as a temporary workaround you can add mappings like these to your Vimrc file (assuming you’re using the Vimrc plugin):
nmap <C-d> 20j
nmap <C-u> 20k
Is that nmap working for you in 15.x? Because that was the first thing I went to try and I can’t seem to get nmap to override the behavior.
Actually turns out it’s not, I just happened to get lucky on the first notes I tested it on
