Uppercase cyrillic letters should change into smallcase, like they do for English.
Uppercase cyrillic letters don’t change.
Just reproduced this bug on Windows as well. (Also thanks, didn’t know about this key binding).
It seems what it’s Codemirror’s bug which can be reproduced on the Codemirror’s website as well.
Interesting, thanks!
Codemirror uses [a-z] and [A-Z] in its regex tests.
[a-z]
[A-Z]
I’ll report this issue in its GitHub repo then.
Reported: isUpperCase and isLowerCase tests for vim mode are ascii-only · Issue #6660 · codemirror/CodeMirror · GitHub
thank you
I’m noticing this issue happening even for English text (not limited to Cyrillic).
Note: my system’s language is configured to Portuguese-Brazil, but I usually write in English.
I have also reported a related bug to codemirror: using the UK keyboard map in vim mode, the tilde key does not register at all. Press it and nothing happens, either in insert or normal mode.
Thanks for the upstream fix. We will update codemirror at some point.
