First make sure to remove assigned hotkey on obsidian
Search & replace in current file = Blank
Go into insert mode by pressing i
→ Press Ctrl+j
→ Press Ctrl+h
In default vim environment,
→ Ctrl+j
acts like an enter key, thus creates a newline
→ Ctrl+h
acts like a backspace key
Pressing both shortcut keys
- Operating system:
This is not a problem to an OS
- Debug info:
YSTEM INFO:
Obsidian version: v0.15.9
Installer version: v0.15.9
Operating system: Windows 10 Pro 10.0.19044
Legacy editor: off
Base theme: light
Community theme: Minimal
Snippets enabled: 1
Plugins installed: 6
Plugins enabled: 6
1: Style Settings v0.4.10
2: Minimal Theme Settings v5.3.2
3: Obsidian Tabs v1.0.5
4: Admonition v9.0.3
5: Relative Line Numbers v2.0.1
6: Vimrc Support v0.7.2
Yes, it seems like those two commands are the only one not supported. Others like Ctrl+W
inside of insert mode works fine. Also you must disable the default assigned hotkey in obsidian for it to work → Close Active Pane = None
