- Ensure that you have vim mode active.
- Press
ctrl+v
to enter visual block mode. - Press
j
a few times to expand the block downwards. - Press
l
a few times to expand the block horizontally. - Hit
c
and notice that even though the selection isn’t rendered, it behaves as if it is there.
The scope of the visual selection is rendered properly.
The visual selection is not rendered, only the current caret position is.
- Operating system: macOS, iOS
- Debug info:
Obsidian version: v1.0.0
Installer version: v1.0.0
Operating system: Darwin Kernel Version 21.6.0: Mon Aug 22 20:20:05 PDT 2022; root:xnu-8020.140.49~2/RELEASE_ARM64_T8101 21.6.0
Catalyst license: vip
Legacy editor: off
A video (zipped) showing the issue.
Vim Block Cursor Rendering Issue.mov.zip (488.2 KB)
