View recently changed hotkeys and pinned hotkeys
Use case
Remembering the custom hotkeys.
I know we can search hotkeys, but that requires you to remember things like this:
  • The functionality triggered by the hotkey exists.
  • The name / description of the hotkey.
New users and people with bad memory might like the following suggestions:
Pinned Hotkeys
Pin hotkeys from the Hotkeys options (hover a hotkey and a pin icon appears to the left of description / name of hotkey).
A dropdown menu on the Hotkeys option page where you can view pinned hotkeys.
Recently Changed Hotkeys
Sort all hotkeys from most recently changed (in the Hotkey options).
View pinned and recently changed hotkeys using a keyboard shortcut
Displays a window split i two; Pinned to the left and all hotkeys sorted by most recently changed on the right.
You can do pretty much the same as pinned hot keys by pinning commands on the command pallet.
Thanks. Haven’t noticed that (or maybe I did notice it, but not consciously, and got inspired by it).
My Obsidian Mobile Android app doesn’t appear to allow pinning commands on the command pallet yet.
Can anybody confirm please?
I still think something like my feature requests could be relevant because you probably would want to pin the custom hotkey directly when you’ve created it (the Command palette options is far away :).
Updated feature request:
Display 2 categories in the command palette: pinned commands and pinned hotkeys.
Pinned hotkeys can be added as described in my original feature request, and also from Command palette.
In the meantime I took the hotkeys.json file found in the .obsidian folder on my Android phone and converted it to .txt using:
This is quite readable with some tweaking until I find a better solution:
EDITOR:swap-line-up >>> Ctrl+1
modifiers
Mod key 1
EDITOR:swap-line-down >>> Ctrl+2
modifiers
Mod key 2
EDITOR:toggle-fold >>> Ctrl+3
modifiers
Mod key 3
EDITOR:fold-all >>> Alt+ArrowLeft
modifiers
Alt key ArrowLeft
EDITOR:unfold-all >>> Alt+ArrowRight
modifiers
Alt key ArrowRight
HOTKEYSPLUS-OBSIDIAN:toggle-bullet-number >>> Ctrl+4
modifiers
Mod key 4
WORKSPACE:split-vertical >>> Ctrl+Shift+V
modifiers
Mod Shift key V
WORKSPACE:split-horizontal >>> Ctrl+Shift+H
modifiers
Mod Shift key H
OBSIDIAN-FULLSCREEN-PLUGIN:fullscreen-focus >>> Alt+F
modifiers
Alt key F
WORKSPACE:close-others >>> Alt+W
modifiers
Alt key W
EDITOR:focus-right >>> Ctrl+Tab
modifiers
Mod key Tab
EDITOR:**focus-left ** >>> Ctrl+Shift+Tab
modifiers
Mod Shift key Tab
SOLVED: I missed the crucial bit …
“Pinned commands are managed on the Command palette options screen under Plugin Options”
Can we adjust this to allow users to see a list of their current hotkeys?
I just made a note with my custom and frequently used hotkeys, and I would rather have just printed/seen what I have in the tool.
Exactly what I was looking for. I have a “Reference” note pinned in my sidebar, and I would like to be able to display some or all hotkeys.
