Disclaimer
Is this plugin completely free? No. Vault Steward itself is free, and local providers such as Ollama can be used without API charges, but optional cloud model providers may incur third-party costs.
Community Directory: https://community.obsidian.md/plugins/vault-steward
Vault Steward: Keep large Obsidian vaults trustworthy
As an Obsidian vault grows, maintaining it becomes a different problem from organizing it.
Broken references accumulate. Frontmatter drifts. Old decisions remain beside newer ones. Tasks become detached from the decisions that created them. Notes can contradict each other while individually looking perfectly valid.
I built Vault Steward to help detect those problems before they make a vault difficult to trust.
Vault Steward is an open-source, local-first Obsidian plugin that scans your vault for structural and knowledge-integrity issues, presents cited findings, and gives you safe repair options.
It never edits a note on its own.
What it checks
Vault Steward currently checks for:
broken internal links, embeds, and anchors
Markdown and frontmatter schema violations
task and decision drift
deterministic YAML policy issues
duplicate entities
contradictions
stale knowledge
ambiguous decisions
Some checks are deterministic.
For cases where semantic reasoning is useful, a configured model can classify or rank bounded, cited evidence.
The model cannot write notes, change policy, approve a proposal, or apply a fix.
Review first, edit second
The workflow is intentionally:
Check → Evidence → Preview → Approve
For proposed repairs, Vault Steward shows the exact Current → After change before anything is applied.
You choose which fixes to accept.
If a note changes after a preview was generated, Vault Steward preserves the newer edit and requires a fresh preview rather than overwriting it.
Local-first
Ollama is the primary local-first model path.
Vault Steward also supports llama.cpp-compatible providers using loopback-only endpoints.
Optional cloud providers are explicitly opt-in and only receive the bounded evidence required for the selected request.
The plugin’s canonical state remains local.
Why I built it
The problem I wanted to solve wasn’t simply having too many notes.
It was reaching the point where a vault contains enough accumulated history that you can no longer be certain everything inside still agrees.
A broken link is obvious.
Two individually valid notes that quietly disagree with each other are much harder to notice.
Vault Steward is an attempt to treat an Obsidian vault as a knowledge system that needs ongoing integrity checks, rather than a collection of files we assume will remain consistent forever.
I’d particularly like feedback from people with older or larger vaults.
What kinds of problems tend to accumulate in your vault that are difficult to catch manually?
