Using the graph to replicate Luhmann's folgezettel (from zettelkasten) without using his ID system
One thing I’ve grappled with in the zettelkasten method is the use of Luhmann’s ID system to create infinitely branching sequences of thought: his folgezettel. (chain of notes)
You can see an example in the digitized version of his slip box: (use Chrome and auto-translate from German if needed) Niklas Luhmann-Archiv
I experimented with using Luhmann’s ID system manually in Obsidian but quickly abandoned it as it was too cumbersome and was not providing value. But it always struck me that it would be nice to have something similar in Obsidian so we can trace lines of thought more easily.
GUESS WHAT: WE DO
The answer hit me today and its blindingly obvious.
By making some simple adjustments to the local graph settings we can gain the benefit of his folgezettel without having to implement his ID system.
Previously I had virtually no use for the graph. Now perhaps I do since it can now provide some interesting meaningful context to each note. I have the local graph as a tab in the same pane as the backlinks list, my “context about this note” pane.
Here is a note titled Locke's 3 ways to manipulate ideas that looks like this:
And its configured local graph now looks like this:
The 3 branches are for the 3 links in the note.
Clicking the link Prefer connecting ideas over connecting notes opens the note and changes the graph to this:
From here we can see three main branches spreading out from this note, two of which lead to more densely linked clusters. It’s easy to hover over them to see what they are and click them to visit the “next note in the sequence” (so to speak).
On the left is the note on Locke. The link between that note and the current note is not an automatically-generated backlink – the current note just happens to also contain a link to the Locke note. (This is important, see the configuration below)
In this way we can now navigate from note to note, seeing in advance which paths lead to more densely linked clusters.
By taking a branch from Prefer connecting ideas over connecting notes I ended up with this graph:
Which I can then use to gain context about the links I follow, if desired.
Settings
These settings worked for me, producing tight clusters that don’t flop all over the display.
  • Depth: 2
  • only show outgoing links (important!)
  • Center force: 0.7 seems good to me
  • Repel force: 15-16 (I had 15.8)
  • Link force: 1.00 (maxed out to the right)
  • Link distance: 30 (all the way left)
This may or may not work for me long term but hopefully it will help someone else!
I agree with you that, for a digital note archive / zettelkasten, it’s best to realize note sequences (chains of thought) via actual links, and not via Folgezettel-style IDs. The latter have issues (such as the problem of decreasing proximity with increasing note archive size, or the lack of multi-parent hierarchies).
Ideally, we’d be able to use link types (as discussed previously e.g. here and here) to describe the nature of a link. That way, we could clearly specify that a particular link points to the next / previous note in a note sequence (e.g. via link types followed by or follows, respectively).
The software could also style links with particular link type(s) in a certain way. For example, in my app, I’ve boldened the arrows/edges matching the currently selected link type(s). Here’s an example with mock-up notes:
I’m less convinced of the need for a “link type” over time, though it could be useful potentially. Currently I just describe the purpose of the link in the narrative when the link is constructed. In particular I find the use of signal statements from legal practice quite effective.
Hey @davecan: Interesting idea. Could you provide an example of a signal statement? Is the idea to just take the title of the next sequential card and turn that into a reference in the current card?
I like this a lot, as it made me discover the ‘Depth’ slider… What I don’t understand is why you would insist on showing only outgoing links. Could you explain why you would think the ingoing links are less relevant? Or is it just to prevent clutter?
Also, what you will still miss, in terms of near-magical Folgezettel perks, if you are not entering notes into a branching sequence like Luhmann’s (12a3c23, 12a3c24) is the serendipitous discoveries that may occur as part of the extra step of deciding where to file the note.
I recently started using tags for that (#A/4/c/33) and I’m optimistic about the return on investment.
Hi @VanderG, did you keep up with the ids? How is that going for you? I’m considering trying them out as well and curious about your results
Excalibrain plugin might be easily used to explore parents/sibling of notes relations Release ExcaliBrain 0.2.0 · zsviczian/excalibrain · GitHub
