Using Space Repetition plugin with Android
I’m trying out the Space Repetition plugin and it works great on my PC. However, it does not seem to be working on my Android phone. The plugin has been installed on my phone; I can see it listed with the other plugins and it is enabled. Also, “Review flashcards” does appear in the menu along with my other plugins. But when I press on “Review flashcards” nothing happens. The other plugins seem to work just fine.
It occurred to me this might be a conflict issue, so I unenabled all my other plugins except the Space Repetition plugin. I closed Obsidian, then reopened it. But it made no difference. The Space Repetion plugin still does not work.
Is there a trick to getting it work on Android, or does everyone have this same problem?
You should look at the GitHub of the plugin next time.
For this, I had the same problem with my android phone. I resolved it with this solution proposed by someone under a GitHub issue about this.
