Using QuickAdd to extract selected text into a new note and then embedding it in original note
Hey everyone, I hope to use the QuickAdd plugin, perhaps in combination with the Copy Block Link plugin, to create a shortcut that does the following:
  1. Extract the currently selected text in the source note into a new note (“destination note”)
  2. Copy the block reference to that text block in the destination note
  3. Insert the block reference as an embed into the source note where the text/cursor was originally located
I have figured out how to extract text into a new note with the Capture choice but struggle with the copying of block references (despite Copy block Link) and inserting it into the source note.
If anyone can help, I would greatly appreciate it!
You can create the block reference yourself, it’s just a “random” combination of letters and numbers, so you can create it and append it to the text you paste into the destination note. And since you’ve created it, you should be able to then construct the proper embed link with combination of the note name and your block reference.
Sounds like a job for the workbench plugin. This one is part of Obsidians core plugins, but there’s also an improved version with the same name by Ryan Murphy
Thanks! How can I access the original note through the QuickNote macros again?
