I’m trying to write a simple (not for me) script that I can run every month to archive the notes that were created that month.
I’ve boiled it down to the following steps:
- Ask question “What month are you archiving?” - I will refer to this as “Response 1”
- Rename folders called Current-Incidents and Current-Requests inside Tickets/“Response 1” to Incidents and to Requests
- Create a folder inside Tickets/“Response 1” named Attachments
- Move all files inside another folder also called Attachments but with path Attachments to the new Attachments folder except the files that are linked to by notes in the Tickets/In Progress folder
- Ask question “What year will this be archived under?” - I will refer to this as “Response 2”
- Move the Tickets/“Response 1” folder to Archive/“Response 2”
- Ask question “What month are you starting?” - I will refer to this as “Response 3”
- Create a new folder called “Response 3” inside the Tickets folder with sub-folders Current-Incidents and Current-Requests
- Echo a reminder saying "Don’t forget to update the Metrics!!!
To be honest I don’t really know. I have 0 or negative coding knowledge and after googling for a lot of hours on the last couple of days I started with a collage of stuff I found and started debugging and trying to fix all the errors shown in the console and I’m stuck with
async function main() {
const month = await window.app.vault
.inputPrompt('What month are you archiving?');
// Rename folders
await window.app.vault.rename(
`Tickets/${month}/Current-Incidents`,
`Tickets/${month}/Incidents`
`Tickets/${month}/Current-Requests`,
`Tickets/${month}/Requests`
// Create new Attachments folder
await window.app.vault.createFolder(`Tickets/${month}/Attachments`);
// Move all files from old Attachments folder to new Attachments folder
const inProgressNotes = await window.app.vault.adapter.read(
`Tickets/${month}/In Progress/.obsidian/attached_files.json`
const inProgressLinks = Object.keys(JSON.parse(inProgressNotes));
const oldAttachmentsFiles = await window.app.vault.adapter.list(
for (let i = 0; i < oldAttachmentsFiles.length; i++) {
const file = oldAttachmentsFiles[i];
if (!inProgressLinks.includes(`../Attachments/${file}`)) {
`Tickets/${month}/Attachments/${file}`,
const year = await window.app.vault
.inputPrompt('What year will this be archived under?');
// Move folder to Archive
`Tickets/${month}`,
`Archive/${year}/${month}`
const newMonth = await window.app.vault
.inputPrompt('What month are you starting?');
// Create new folder and sub-folders
await window.app.vault.createFolder(`Tickets/${newMonth}/Current-Incidents`);
await window.app.vault.createFolder(`Tickets/${newMonth}/Current-Requests`);
console.log("Don't forget to update the Metrics!!!");
main();
which I’m pretty sure that is probably 99% wrong.
Any help is seriously appreciated.
