Using Obsidian's folders for other documents?
I tried to outline some documents with Obsidian, but I couldn’t manage to use it effectively for something a bit more elaborate (if there is a lot of text, not just “lists”).
So I may use another tool (OmniOutliner) for some specific work.
Is it possible, since the folder organization of Obsidian has become my main work organization, to put these OmniOutliner documents in the same folders (I know they won’t be visible in Obsidian)? Without any risk? It’s a simple matter of practical organization and centralization of documents. Thanks for your help!
Since your vault is stored locally on your computer, yes you can add other documents to your vault.
