I’m a new person in the Obsidian Family.
The main aim of using Obsidian is to organise and build a knowledge bank of the literature I read in an easy and connected way, which I will then use to write academic papers.
As I’m still new and navigating my way in Obsidian. I would appreciate it If you could guide me to some resources (youtube videos, etc.) to help me learn about Obsidian, especially its use in academia. Also, I would like to know if there are any other tools I should use with Obsidian to make its use for this purpose easy.
A big part of my Obsidian vault is centered around the literature, reading papers, identifying key concepts, etc. Consequently, I recommend checking out Zotero and the Zotero Integration plugin. It takes a little time to set up, but it gives you a lot of options to make very durable notes.
The way I use these tools is as follows. I have one note in Obsidian for every paper/video/talk. The note contains the abstract and the bibliographical reference, as well as my summary of the paper. Then, when I’m working in a new file, I can refer to the paper by making a link to that note. For instance, I could have a sentence like:
The [[MOS]] algorithm was introduced in [[GlahnUseModel1972]].
The backlinks of the GlahnUseModel1972.md note give me a list of everywhere I refered to that paper in my other notes, which is nice.
Bryan Jenks also has a lot of good stuff. His videos are quite long but he goes into a lot of detail. I got started with the workflow I introduced here thanks to this video by him, but I modified it a bit, so it’s not a perfect reference anymore. Notably, don’t use that pipeline to import Zotero references into Obsidian. Zotero Integration makes that easier in my opinion.
However much - as with Obsidian’s development - with both of them are things like browser like environments, bookmarks and newer plugs, etc., it is very easy to say - pick a ‘last year’ vid only to find a newer better way to deal with the ‘task’.
When I bring new literature content into my vault, I sometimes assign high level tags and nested tags, in YAML, for the content in the entire note; this changes over time as well. Tags like #craft/antecedent, #style, #voice, #pov/first-person, #process, #prompt, and #examples.
For sections and blocks I use in line links that are specific to that selection. Links like [[great sentence]], [[direct object]], [[second-person]], [[checkov]]
Using search you can find tags, links, and keywords - you can save searches as bookmarks.
The core plugin, Canvas, is great for tossing ideas onto and pondering.
As you use your vault, keep refining by adding or deleting tags and links.
Best wishes and let us know how use Obsidian, this forum and discord are a gleaners paradise.
@writtenfool: I really like your approach, or what I can understand of it. I don’t suppose you have a skeletal vault or something else that you could release which would provide examples of these ways of using Obsidian, would you?
