Using Obsidian as a Therapist
Introduction
Background: An early professional looking to have a safe, locally-stored place for my counseling/therapy notes. Tinkered with Obsidian for the past year and a half, using it for grad school, research, case notes. I’d love to hear feedback from fellow mental health professionals, especially on the security & practicality side of this workflow!
What I’m Trying to Do: create a secure, useful clinical process/psychotherapy notes system that can also provide high-level case tracking, a quick reference point for my ideas, things to remember about clients, etc. I’ve heard that many therapists use Word docs for their process notes (yikes!), but I’m looking for something a bit faster, more robust, more customizable. I’m hoping to use set-up this once I start seeing clients in a private practice setting.
Parameters: Psychotherapy/process notes must be aligned with HIPAA, which can be a can of worms. However, psychotherapy/process notes are a distinct category, and they are not included in a client’s medical record. In other words, these are notes that are for the therapist only.
In the spirit of security (and compliance:), this vault will include full encryption. For my use case, these notes will not be synced to other platforms; they stay local to a single device and an external backup (also password protected). However, with tools like Cryptomator, I think you could justifiably use a P2P sync option or even a cloud service to access notes across devices (more on this below). This would be especially useful if you’re a counselor/therapist who uses a tablet to take handwritten notes.
Risk Analysis: Installing any theme or community plug-in increases the risk of exposure. For this workflow, you would only need to install Dataview. I don’t think there is a way around that for what I’m looking for. That is the main “vulnerability” of this approach (I’m not sure how “risky” or not this is, would love to hear thoughts below!).
Vault Encryption: I followed this guide from Jonathan Pritchard about using Obsidian with Cryptomator. This way, I can easily lock and unlock the vault, which provides an extra layer of protection for the notes. In this video he also shows how to use Syncthing with Cryptomator as well, which would enable the aforementioned tablet workflow.
Structure
Here is a quick overview of the vault. I will likely not explain all of the quirks of my approach, but this should cover the basics.
Templates
Client Notes: MoCs for each client.
This dynamically pulls from individual session notes using Dataview. The primary query here is a table that provides a brief overview of each session, including date, interventions, reminders (easy to forget details), rough idea of what to bring to next session. This note also includes some extensive logistical information, such as their usual availability for sessions, order in the day, etc. I use the following naming convention: FirstLast-Year-Month. Something like: NickC-2023-05.
Session Notes: Working in the dirt.
My template here is nothing special, and everyone’s template will be slightly different depending on what they find most useful. Essentially, there is a metadata section and a fleeting notes section. Most useful for me are interventions used, session summary, and ideas for future sessions, as these will be pulled into the Client Note. Just recognize that if you change the session note template too much, you’ll need to update the dataview query in the Client Note. The naming convention: InitialFirstLast-year-month-session-#. Something like AmbB-2023-05-session-1.
Client Hub: Putting it together.
The bigger picture makes sense after understanding the groundwork, right? Well, this is the bigger picture. This note is comprised of queries from the Logistics section of the Client Notes and summaries of all Client Session Notes. The MoC of therapy land. If you work in different settings, agencies, etc., you could have a hub for each place.
Folders (are Fun!)
I experimented without folders in my main vault for a while. Fun until its not. I like a lightweight structure, something that allows me to use the root folder as a sort of processing area. So, the major folders of the vault:
  • Atlas/
    • client-hub
  • Clients/
    • Client 1/
      • client note
      • session 1
    • Client 2/
      • client note
      • session 1
    • z Client Archive
  • Extras/
    • Attachments/
    • Templates/
      • client-note-template
      • session-note-template
      • metadata-template
  • Resources/
  • Misc/
  • root used as inbox, notes are “processed” once they’re filed away.
Really, not much to it! I like the folder approach because its easy to move an entire client into the archive folder then forget about it.
Additionally, if you’re going the Excalidraw template route, the folders help keep everything together for each client.
Dataview
I think it’s easier to see the queries by diving into the vault. Using Dataview, tags indicate status (#Client/Active) or type (#Type/Session); links generally connect the notes to the client, or client to a hub (MoC). These are then used in the queries to create overviews per client and across all clients.
Final Comments
I hope this is useful to some people! As I’ve continued investigating whether I want to use a tablet, it has become more interesting. I’m thinking about syncing (using Cryptomator and Syncthing) and using Excalidraw to take notes in session. I have 0 experience with Excalidraw, but I know you can create templates, which seems useful. Or, perhaps native handwriting support will be included in the near future? That new logo is looking nice and pointy… :wink:
Either way, I’ve attached the vault below. Any comments or questions are very welcome!
Radical Rogerian.zip (434.1 KB)
Also, here’s a screenshot of the vault to get a gist of what’s possible with these queries:
This is fantastic.
I’m new to Obsidian, but I’ve also been thinking about how to organize therapy notes and relationships with it. Thanks for sharing your work.
This is great!
I never used Dataview before, so went a bit silly trying out new ideas. Here’s some changes I made—perhaps it can be of service to others.
First, my dear therapists, do yourself a favour: make a template for your induction questionnaire, initial needs assessment, or whatever you call that screening battery you complete with new clients.
And add a keyboard shortcut for duplicated notes (speeds up the workflow)
Dates seem a bit screwed up for me, following some north american convention, so in the session template I forced the format to follow:
date:: {{date:YYYY-MM-DD}}
Year-first, for later sorting
I added an automatically incrementing session count to the client note:
sessionCount:: `$= dv.pages("#Event/IndivSession").where(page => page.file.folder == dv.current().file.folder).length
Under this is a payments counter, which I do manually and probably won’t ever wrangle it to fill automatically.
I didn’t like that each note needed it’s own link (e.g. “[[HarP-2023-02]]”), so tweaked the table in the main client note:
```dataview
table date, summary, interventions, next
from #Event/IndivSession
where contains(file.folder, this.file.folder)
sort date desc ```
I think how this works (I forgot what I did here a month ago) is that the WHERE part checks that the session name includes the client’s cipher. E.g. “Joe Bloggs” gets cipher “JB”. Under folder “Clients” is a folder called “JB”, and under this is the main client note (with this table) and all the sessions - “JB-0”, “JB-1”, “JB-2” etc.
A few things that aren’t working like I want them to:
  1. after reboot, opening the vault issues a security check, wherein I have to confirm trust of authorship of the vault
  2. dataview always fails to load after the vault is opened, even if I keep the encrypted directory unlocked. So I have to manually enable community plugins each time.
  3. I tried using an internal link to the vault from my main (unlocked) vault, but closing the encrypted vault kills the link. So I have to manually select the folder to open as vault each time I decrypt the directory
Each client deserve some CANVAS file… There you can map different topics, problem, in one cohesive picture. Probably this canvas file should be only for your use. And you can keep it open during session, as you can glance there and have birth view of all information.
Hey hey! I spoke the therapist who created this and we’ve set up a Discord server to discuss taking process notes in therapy in Obsidian, plus other tech realatd therapy goodness! Let me know if this interests you and I can send you the link to join the server.
Hey Antzus! I spoke the therapist who originally created this and set up a Discord server to discuss taking process notes in therapy in Obsidian, plus any other tech related therapy goodness! Let me know if this interests you and I can send you the link to join
Actually, adding here. Not sure we can DM on this fourm.
Hi phimmelstein. Thanks for the offer. I don’t really use Discord but I’m curious what developments you might have.
Can you please send a new invite? Your last one in the comment has expired.
Hello folks @phimmelstein and @BSaubolle - do you still have that discord going? I am building a system for this exact purpose utilising on device AI to help the system function in a more stream lined way. Would love to chat!
I don’t think that discord is going any longer. But I’d be very open to hearing about your workflow, especially on device AI. With Bases, this whole thing becomes much easier, too.
Therapist here - it’s interesting to think about escaping commercial EHRs. Two initial issues came up though as I was thinking through this - One is that you don’t have audit ability of when records were accessed and when, which is required by the HIPAA privacy rule. Two is that you also don’t have intrusion detection - knowing when someone actually tried to break into the system. I’m curious how you’re accounting for these.
For AI - if you run LLMs that introduces new attack vectors. It seems like the best way to counter this is to run the entire system offline. E.g. a router/tablet/computer that all do not connect to the internet at large. If you connect to the internet then you always have the threat that someone could hack into your “local” system. Perhaps you could download all of the apps needed one time and then go from there. Electron apps are great for flexibility, but they are notoriously insecure.
Thanks for connecting this conversation to specific HIPAA rules. I’ve been watching this thread over the last couple years and have been day-dreaming of this for about that long. I also want to avoid paying EHRs for a few reasons. Additional vendors doesn’t come without additional risk in terms of breaches of confidentiality and privacy. The vendor themselves could make mistakes and violate their own BAA. They can get hacked. They could get subpoenaed themselves, and possibly be prevented from notifying me about that. With current political situations, it’s not outside the realm of possibility for a company to be forced to hand over data regardless of whether or not its HIPAA-protected. There’s still plenty of risk with an ill-fitting EHR, especially if you work with vulnerable clients.
I think if you add a couple things, you can satisfy most of those HIPAA privacy rules, at least for a solo practice. Depending on the OS, Obsidian could be barred from using Internet, to avoid any concerns about leaking data through the closed-source program. Git versioning with GPG signatures and a YubiKey provides a pretty tight audit log of any write changes. Having full-disk encryption at rest prevents a lot of unauthorized access; moreso if the device itself is entirely offline. Depending on the OS, you could also have access to a read audit tool, and intrusion detection tools. These things have very little to do with Obsidian, which is basically just a pretty text file browser within this stack.
I’m going off of some pretty brief summaries of HIPAA, though, and would love to talk more about this with others thinking of doing this.
