I have tried concatenating how a normal image embed works in Obsidian markdown
Reading through dataview reference documentation
There are a lot of people embedding an image into their dataview tables by using a URL in the frontmatter as follows:
table Author, ("") as Cover
However, I wish to use a file that is added to my Obsidian library (the attachment that gets auto-sorted to your chosen attachments folder when you drag and drop). This would allow a more permanent picture without having to upload to imgur or hotlink to a URL that could eventually break.
Thank you The Buccaneers Bounty for introducing me to DataView and all the neat stuff that Obsidian is capable of.
I believe this will work! Although I do use Google Drive + RClone to sync my Obsidian between my Windows battlestation and Zorin OS (Ubuntu) laptop. So I am imaging there will be issues with a static path since the file paths would be different due to the really different systems. I will try to make your suggestion work with a relative path when I get a chance. Thank you for the reply!
I need to create a link to an attachment in the vault rather than in a URL to a local drive. The problem is when I am on my phone I can not see any of the images because the URL link is to a C drive o D, my phone doesnt work that way. I would use something like <vault=file1.png>
