Hi everyone, I’m new to obsidian and i was wondering if you can use HTML tags like select or radio group or check-boxes and then store the value selected in a variable so i can then query it with data view
My idea was something like:
recommend::
Yes
No
Maybe
and then my data view would be something like:
LIST
FROM "Tests"
WHERE recommend = yes
Maybe this is not possible if so maybe can you suggest me a workaround with that
Thanks
Hi thanks for the answer, yeah i though of that solution too but the thing that i wanted to use was a select tag from html, and use that to select the corresponding value, it can work as you showed me yes but i was wondering if you can use html like selects, radio buttons to select a value instead of writing it.
