Using dataview to filter Tasks plugin priority
Tasks plugin and Dataview
I’m creating a workflow where i want to use the Tasks plugin and Dataview.
I like the task metadata (and the pop up options) but like querying with Dataview. What i am struggling to do is filter based on the priority created by the tasks plugin.
For example - this is what my tasks look like :
  • [ ] task 1 :arrow_double_up:
  • [ ] task2 :arrow_up_small:
  • [ ] task 3 :arrow_down_small:
My dataview query pulls these tasks, but i am not sure how to query the priority metadata on each task.
I thought that i may be able to use something like:
WHERE !contains (text,":arrow_down_small: ")
I appreciate your help!
Okay. So the suggestion i posted actually works if you make sure there are no spaces before and after the character. e.g.
TASK
FROM "Inbox"
Where contains(text,"⏫") AND !completed
